Desperately trying to backup a couple of DVD's (DVD to .AVI) but whenever I try it with Fairuse (which worked perfectly in the past) I get the following error: http://xs.to/xs.php?h=xs109&d=06481&f=fairuse.jpg
How can I bypass this? Or what would be the best way to backup the dvd? I'm trying to make them either a 700MB file or a 1200MB file .. thanks!!![]()
Same on all dvds?
Are you using latest fairuse wizard 2.5?
Or try AutoGK. -
i have no idea to solve your problem,but if you want use other problem,i recommend SPAMdvd ripper ,it could back up dvd to avi with fine quality.and it have three try for free.you could have a try.
website:SPAM
How do you backup your o/s?
By johns0 in forum PollsReplies: 23Last Post: 6th Apr 2011, 06:31 -
Backup Program
By HotDamn! in forum ComputerReplies: 7Last Post: 10th Mar 2010, 00:36 -
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 09:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 01:50 -
backup software
By alintatoc in forum ComputerReplies: 21Last Post: 25th Mar 2009, 14:23
