This is a little different problem that I've seen searching through the forum.
I've used Ulead DVDWS for about a year with no problems. In a short program with 4 clips, one clip is off. The avi file plays OK by itself. In the final DVD, audio plays fine but video slows down during the last 10 seconds only. I tried recapturing it from a final mix and original camera iso recordings but get the same results. Any ideas? Thanks!
Well, problem solved! I took some clues from previous posts on "audio/video out of sync" and tried a different encoder--CinemaCraft Basic. All is well. Although no one responded to my post, I really appreciate the incredible site here.
Glad to hear you solved it...
I looked at this thread, but haven't heard of that particular problem before, and I haven't used DVD Workshop either...
Audio suddenly drifting out of sync
By dubmunkey in forum Software PlayingReplies: 9Last Post: 13th Aug 2010, 08:46 -
Stretched duration after IVTC (sync issue: audio drift)
By ARTO65 in forum DVD RippingReplies: 11Last Post: 10th Jun 2010, 20:38 -
Getting Audio sync issues with handbrake suddenly...
By nodollas in forum Video ConversionReplies: 4Last Post: 30th Jan 2010, 06:44 -
cant SUDDENLY play all video files, only audio!
By dwardwarbinx in forum Software PlayingReplies: 6Last Post: 7th Jul 2008, 13:34 -
capturing using different compters for A/V = mux drift/sync issues
By drstrust in forum Capturing and VCRReplies: 4Last Post: 17th Nov 2007, 09:13
