One other question...
I can simply go into device manager under Windows XP and look at my DVD drives "properties" and see what region information is listed.
It also gives me the ability to choose a country and change the region setting up to "X amount" of times.
(Both now are listed as region 1).
So, what is all the talk about proprietary firmware to do this? Can XP do it for you?
Frankly, I can't remember....perhaps I did reburn the drives at some point.
THANKS
I'm not thinking...the XP device manager will only allow the region to be set for windows, right?
I would need to flash it with new firmware if I wanted to use the drive in a DVD player? -
4 times are left for you to change it before it stops, you've used 1 of 5 when changed from 'region not set' to 'region 1'. Changing firmware to override this limitation had been used until safe software methods appeared like DVDRegionFree or DVDIdlePro (some people like AnyDVD).
Samsung BD-P1590/BD-P1600 Foreign Firmware Flash/Region Free Issue
By 5arge in forum DVD & Blu-ray PlayersReplies: 12Last Post: 15th Apr 2012, 19:32 -
Samsung BD-D6500 Region Free Firmware
By adam177 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 13th Mar 2012, 00:03 -
Sony BDP-S370: Firmware upgrade to 567 and region free hack
By Nosh3 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jan 2011, 07:57 -
Pioneer DVR-115D - Help on Region Free firmware and USB 2.0 use
By FulciLives in forum DVD & Blu-ray WritersReplies: 13Last Post: 4th May 2008, 21:35 -
region-free code/firmware for DENON 1740
By abraxox in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Nov 2007, 15:05
