  1. Hi,
    Is it possible to connect two monitors, two mouse, and two keyboards, to a very high spec PC, and run it like two PC's?
  2. Member Conquest10's Avatar
    Chicago, IL
    I'm not sure if its possible or not but I got to ask: Why would you want to do that?
    His name was MackemX
    Feb 2004
    Australia
    In short ...no
    But you can seperate the work load across two monitors .
    Apr 2004
    Miskatonic U
    Yes, it is possible. Basically using KVMs and virtualPC type technology it can be done. That said, the only setups I have seen involved adding specific hardware into the system as well.
    Read my blog here.
