    Nov 2003
    SACRAMENTO, CA USA
    300G (320G) Maxtor Basic HD SATA via SATA Card
    WinXP Pro SP2
    Compaq 6450NX Motherboard
    upgrade an e-GeForce (NVIDIA) 256MB/DDR2 video card by EVGA via AGP 8X slot (not PCI).
    Windows cannot detect this hardware. When start Windows keep reboot after reboot, whether I selected safe mode, safe mode with prompt, start Windows normally etc. it keeps on rebooting. I also disabled the intergrated Video on the board still no avail. Remove this AGP card PC will starts Windows OK. Any ideas?
    Thanks.
  2. Member lacywest's Avatar
    Aug 2001
    California
    There is alot of GeForce Video Cards out there ... do you know what model it is ??
    Could it be sucking too much power from the power supply ?
    Does it use separate power connections to the power supply ??
    USA
    Unfortunately, that sounds like a defective video card. Have you made sure it's properly seated in the AGP socket? And I assume that 8X card is compatible with your motherboard? (Though it should be.)
    Feb 2004
    Australia
  5. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Clearing the BIOS may help (then disable onboard video again) or locating a motherboard BIOS flash upgrade.
    I think BJS is probably right....a 200 watt p/s with any modern video card especially ones that have a power connector is weak.
    Mar 2004
    London
    Compaq 6450NX uses AGP 4X 1.5v
    Nov 2003
    SACRAMENTO, CA USA
    Update:
    I got a new Video Card today at Compusa (fairly good sale price) 256MB DDR PCI not AGP http://compusa.shoplocal.com/compusa/Default.aspx?action=browsepagedetail&storeid=2402...id=-2094011629
    and it works! Thanks all for your inputs!
