I'm wondering if there is a program that can batch encode audio from avis w/ vbr audio. Like you can do w/ vdub but I want to do several files at the same time. I'm trying to convert to dvd mpg w/ tmpgenc plus but the vbr audio seems to bloat the file size. If there is someway to make tmpegenc act right w/ out saving the audio as a wav that would work as well. Anyway I appreciate any answers I receive thanks
- nexus
"We were in barstow on the edge of the desert when the drugs began to take hold."
Don't convert the audio at all with tmpgenc. Use batch ffmpeggui and batch all avis to mp2 or ac3. Then when you author the dvd add the video and audio file.
Besweet (Gui) can convert audio directly from AVIs.
In batch mode you cn just drop the files into it
Works well for MP2, less so for AC3.
Remember to set the sample rate to 48000.
Bitrate: 128 k is about the minimum, lower won't save much space compared to the video files.
Batch conversion to DVD
By qbecerra in forum Authoring (DVD)Replies: 4Last Post: 30th Sep 2008, 12:45 -
Batch .tivo Conversion
By sapph in forum Video ConversionReplies: 5Last Post: 23rd Jan 2008, 15:21 -
How to set audio conversion settings in batch mode for VirtualDubMod?
By montango in forum Video ConversionReplies: 2Last Post: 14th Jan 2008, 03:56 -
Batch conversion
By karlitus in forum ffmpegX general discussionReplies: 2Last Post: 23rd Nov 2007, 11:33 -
batch rm conversion
By kcchesnut in forum Video ConversionReplies: 1Last Post: 1st Jul 2007, 20:01
