I noticed a post by a guy named Tarvish, he asked
I'm with Tavish and would like to record video footage at the highest quality possible. Any suggestions yet? I've seen component capture cards but they are like $900. Kind of pricey. Anything lower priced? Maybe around 200 to 400 buckaroos?Hey guys,
Im wanting to record footage from my xbox 360 onto my pc. It uses a 720p signal via component cables. What card can I use to capture my HD signal in 720p on my pc? Any ideas?
-tavish
Results 1 to 9 of 9
The AJA Xena LH or Xena LHe
The difference is that the LH is a PCI/PCI-X compatible card whereas the LHe is a PCIe type card.
Either way you won't like the price.
Here is a link to the AJA Xena LH ---> CLICK HERE
Here is a link to the AJA Xena LHe ---> CLICK HERE
Cheaper solutions? You find one you let me know
- John "FulciLives" Coleman
P.S.
Actually one of the JVC D-VHS VCR units may work for this. That would be nearly 1/3 of the price of an AJA Xena not to mention no computer overhead. Take a look at the JVC HM-DH5U and don't let the MSRP scare you as the street price is less than half of the MSRP. In fact here is a link for you ... CLICK HERE
*** EDIT ***
Scrap that ... the JVC doesn't offer COMPONENT input."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
That was an interesting PCI-e card FulciLives... I've seen some cheaper Component cards, slightly cheaper in price, but still a tad to much ($999). Anyway thanks for the links. Also that HD VCR recorder was quite interesting (though I have no interest buying it).
If I wasn't broke all the time I'd definitely buy the JVC D-VHS as it seems to be the cheapest way to record and archive HDTV ... at least for the time being.Originally Posted by aphonia
Afraid it won't work with the XboX 360 though.
I just came across this capture card:
http://www.shop4tech.com/?go=view_item&id=5101&r=183
Does anyone know if it does HiDef capturing through component? It only has a $150 price tag on it. -
no it will notOriginally Posted by aphonia"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
No component input on the DVIco card. Appears to record off an HD tuner module and have the usual suspects of composite and "S" video in.
Component input is availabl wit: http://www.videoguys.com/pyroAVlink.html although it's 480i. -
I've seen a few posts on various forums where people are looking for ways to capture their Game Console's HD gameplay.
You might look into the possibility of:
1) BlackMagic Intensity HDMI PCIexpress capture card
2) Gefen Component with Audio to HDMI converter
3) 3+ hard-drives in a raid-0 setup capable of 119+MB/s as required for capturing
If it were me (because I have a couple real nice HDTVs), I'd just buy an HD camcorder and optimize a setup for recording the gameplay.
Do some searching around the web and you should be able to work out some solution together with some of these other guys looking to do the same thing.
Let us know what you end up doing and how it works.
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
720p Component Capture Cards? (for videogames)
By duderdude2 in forum Capturing and VCRReplies: 15Last Post: 10th Dec 2009, 14:38 -
Trying to find Capture Card - w/ Component input
By tS_veXed in forum Capturing and VCRReplies: 63Last Post: 21st Nov 2008, 08:08 -
Need USB/Firewire 480p capture over component
By Try4ce in forum Capturing and VCRReplies: 2Last Post: 3rd Jan 2008, 16:50 -
Component video capture with PYRO A /V Link?
By theinv in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2007, 18:47
