When I tried making a copy of my DVD disk, the entire program froze after it did the analysis. It was able to read all the files on the DVD, but when going to press the Back Up TAB, the program froze. Do you recommend making an ISO first? Or ripping with a different program then use DVD Shrink? Please Help
Also is there a better way now instead of using DVD Shrink to make copies of movies?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Could be because of a newer encryption. I use RipIt4Me, along with a special version of DVD Shrink with ImgBurn, to automatically burn. You can get Shrink/ImgBurn from here: http://forum.digital-digest.com/showthread.php?t=63869
You could also use DvdReMake or if you wanted to backup to dual layer DVD with no changes, DVD Decrypter. You would need to use another program for the new encryptions with this method, though, like DVD43 or AnyDVD. -
In other words DVDShrink and DVDDecrypter are old and no longer being updated. In order to still use DVDShrink you will need to rip the DVD to your HDD with a newer decrypter like DVDFabDecrypter. There are other methods, programs as well but I was never a huge fan of single click programs for my DVD-ing.
Also keep a program called FixVTS in mind...a great little tool to have in your arsenal and it is also used by at least one of the single click backup programs. -
But doesn't making the iso of a DVD, and burning it onto a disk decrease the quality of the original DVD by a lot more than if it was just straight copying of the original DVD?
Also I am trying RipIt4Me for the first time, and it says Find FixVTS, what does this mean?
And create PLS for DVD Decrypter? Need help in ripping...Thanks! -
Here is a god place to start reading about your present problem.
https://forum.videohelp.com/viewtopic.php?p=1397871#1397871
You also need to do some SERIOUS reading since your questions are coming from all over the spectrum of "DVD-ing".
DVDFabDecrypter is the latest/newest code cracking DVD ripper.
DVDFabDecrypter is NOT the same as DVDDecrypter.
Ripping an ISO/or folders of a complete DVD will not result in quality loss.....only after you shrink it with DVDShrink(or other transcoder) will you start to remove quality.
A DVD9 is a dual layer disc.
A DVD5 is a single layer disc.
You will need to know those terms as well....along with many others. Use the glossary at the top left of the main page.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
burnt dvd's freeze 3/4 through the movie
By sc0rpthir13en in forum Newbie / General discussionsReplies: 8Last Post: 30th Oct 2008, 19:40 -
more dvd freeze problems
By dblake2 in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2008, 11:27 -
dvd architect 4.0 chapters freeze.
By rb_jr in forum Authoring (DVD)Replies: 4Last Post: 4th Jan 2008, 09:38 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59
