For non copyrighted material that it over 2hours, what is best method?
I"ve used popcorn to compress, but I think you get high risk of seeing blocky/screwy looking video, right? are people using dual layer? is that the best solution, or do people have good results with popcorn?
Results 1 to 15 of 15
Have you done side by side comparison with Popcorn? maybe it's no better, the same.
If you do have access to a PC, DVDShrink has always been a great tool. Better quality results than Popcorn by a long shot.
If you can copy the VIDEO_TS folder over to your hard drive, you may use ffmpegX (with Apple's MPEG2 codec) to recode to a lower bitrate and end up with a single-layer disc's worth of content. -
dvd shrink, not mac? this is mac forum. dvd2onex, never heard of it. why would popcorn not be as good? what is DL?
DVD2oneX (aka DTOX) Is a commercial program to do a
fair amount of work with VIDEO_TS files, plus compression
and (with version 2) burning. "DL" is "Dual Layer."
I don't have issues with Toast/Popcorn compression (They
are the same) on my regular TV or on my 1024x640 display.
Try it. Some people swear by DTOX's compression algorithm.
I think it may be "I stand behind what I sit behind."
Try a few things with your own eyes. That's the test that
matters. If you find a DL copy so superior to a compressed
one, shell out the $2 per disc instead of 30¢. Your call.Al Bloom -
If you are using 30c DVD media, why not just span the movie across two discs? Sixty cents wont break the bank, and you will have a copy without additional compression.
.30 or 30 centsOriginally Posted by kevs
He referring to the current cost of good quality single layer media, like Taiyo Yuden. -
thanks guys, I know 7 is current, but isn't 8 coming out any day?
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 18:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 16:43 -
Copying an already copied dvd
By Angel87341 in forum MacReplies: 8Last Post: 12th Feb 2010, 15:54 -
Copying a copied dvd
By Angel87341 in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 13:56 -
Can a music CD be copied into a DVD?
By coody in forum AudioReplies: 6Last Post: 13th Oct 2008, 18:32
. moving you.
