Hello everyone.
I'm dealing with a big problem with DVD LAb Pro.
I've donw a menu with Lab Pro, but when I'm trying to export my project it only exports the menus, but I want it to export with the Movies too. I know this must be something easy, but I'm getting desperat.
So please someone help me.
Edit --»» This are the setings I have:
Results 1 to 18 of 18
Export? I guess you mean "Compile"...
Can you show us the log from the compile process? -
Well, you can always compile the project again and take a screenshot of the log window... Actually, it's called the "Compile" window. If there were errors at some step of the compile process, they should appear there.Originally Posted by PTsniper
Ok, the source is a folder at my desktop.
I put the mocies directly without demultiplexing.
The version is 1.53 (I gess)
And I'm going to take a screenshot of the log as soon as I can. -
Did you demux when asked ? If not, demux and try again. DLP prefers working with elementary streams, which is why it offers to demux them for you. As you have not given any information about the source ("a folder on my desktop" does not count as information - how they were encoded, from what, which what settings would count as information) I can only assume at this stage that the fault lies with your source material.
1.53 is not the latest pre-2.0 version. I would suggest updating to 1.6xRead my blog here.
OK, thanks.
So You're assuming that the problem is from my vids right?
Thanks -
I would told you, but I don't know those stuff.
I can tell you that the Vids came from a DVD of mine, then I edit them with a Mpeg Video Edit and I convert the Mpeg files again to Vobs with VStrip (Or something like that), then I just imported the vids to the DVD Lab Pro and I made the rest.
Does this helps? -
What is the size of your Video_TS folder that DVDLab pro compiles into?
oh, alright thanks
Besides, I have another problem with DVD Lab (not the Pro one), after I tried to make my DVD in DVD LAb Pro and nothing, I tried with DVD Lab, but now I'm facing another problem,
after I write my DVD and put it on my DVD player it appears the menus, but not the movies (but they're there, but I can't see them, maybe I have a bad connection, but I don't think so)
Thanks, once more
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
