So what's the max size svcd file I can get on a 80 CDR without overburning?
I would assume 702 MB (sans the 1.4 meg for the file system). But I notice the bitrate calulators suggest something closer to 750 MB. PVAStrumento even cuts selected mpegs into 792 MB files calling them (80min CD-R SVCD format).
How can this be? How could I get 792 MB on a 702 MB disc?
--mc4
sorry for the noob question. I sometimes have trouble finding things on this site.
Thanks -
Assuming only one video track with minimal overhead, you should be able to get about 795 MB on one 80min/700MB disc on a SVCD.
This apparent overcapacity is because the video track on S/VCDs is written in MODE2 Form2 sectors. In this, you get 2324 bytes per sector of user data.
In ordinary CD-ROMs (which is where the 700MB capacity figure comes from), you only have 2048 bytes per sector.
There are 360,000 sectors on an 80min CD so if you do the multiplication, you can work out the capacities.
There will be some overhead on the SVCD but if it is minimal (e.g., one track only, no menus) then it should be no more than 15-20 seconds.
Regards.
Michael Tam
w: Morsels of Evidence
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 13:58 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14
