I found a good article about removing scratches.
I work with 20 some men and every so often they bring me a Disk that is scratched.
I do use tooth paste to remove the scratches and I'm usually successful.
Anyways here is the link >>> http://www.hardwaresecrets.com/article/77
and here is the article.
Recovering Scratched CDs
Author: Gabriel Torres
Type: Tutorials Last Updated: November 23, 2004
Page: 1 of 1
Every user has had trouble with a scratched CD. In the case of data CDs (CD-ROM), the drive cannot properly read the CD, giving rise to reading errors. In the case of audio CDs, the CD skips when we play it.
The first thing to do when coming across a CD with a read error is to clean it, to check whether it the error is not being caused by a dirty surface. You can even wash the CD gently with a little detergent, using your fingers to clean it (avoid sponges, since they can scratch the CD). If the error persists, try reading or playing the CD on another drive. If another drive (or CD player, in the case of audio CDs) gives the same result (read error or skipping, in the case of audio CDs), it will mean that the CD is scratched.
Looking against the light, the recording surface (the flip side of the label) of a CD with this kind of trouble will allow you to easily see one or more existing scratches. A CD's data is recorded on a metal layer inside it, a silvered layer on commercial CDs, which is usually golden on CD-Rs. This metal layer is inset in a transparent plastic covering (polycarbonate), used to protect the CD's metal layer and allow printing a label on the side not used for reading.
A CD-ROM drive or CD player utilizes a laser beam to read the metal layer. This laser beam crosses the plastic layer and reads the metal layer. If the plastic layer is scratched, the beam will be unable to pass through it, resulting in a read error or skipping the music. In other words, the data to be read are still in the CD, the trouble lies in the layer of plastic.
As the CD's contents are preserved, a scratched CD can be recovered by polishing its plastic surface. If, after carrying out the above cleansing, the CD persists in giving reading errors, just polish the CD with toothpaste. That's right, toothpaste. It works wonders, and you won't spend a fortune buying professional cleaning kits. Polish the scratches with a cotton swab, rubbing gently the paste-imbued swab over the scratches until they disappear or until you notice that you have removed them as far as possible. Sometimes the paste may cause new scratching, but it will be merely superficial and easily removed. After clearing the scratches, wash the CD in water.
If there are still scratches that the toothpaste has not managed to removed, use a metal polish (Brasso) in the same way as described above. Finally, rub Vaseline on the CD, very gently (do not press hard), from moving out from the centre to the rim.
The last step will be testing the CD. If it starts working properly, great. If not, repeat the above procedure, looking for the scratch that is causing the error and concentrating your polishing efforts on it.
Uh... you can get CD resurfacers for about $20 in any Staples... And the liquid sealant is available as well, or even any Circuit City.
For the last ten years I have been fixing scratches with HOT HOT HOT water and a t-shirt. Rub it super hard and super fast.
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 13:38 -
scratched discs
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 17:42 -
Recovering MiniDV Audio
By mushmouth37 in forum MacReplies: 1Last Post: 31st Mar 2008, 12:54 -
Recovering scratched audio CD
By Des in forum AudioReplies: 11Last Post: 31st Mar 2008, 07:54 -
Recovering Video Files
By Cougar94 in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2008, 13:50
