I recently recorded some highschool video projects onto a few dvd-r using my pioneer dvd-r recorder. Now I am looking to reedit and author these onto a dvd. From my limited understanding i am to demultiplex the dvd to convert it into a mpg file so I can edit it. I tried this the first time using dvd decriptor and it worked perfectly making mpg files with both audio and video that i loaded to mt editing software(vegas). I tried it again and all it gave me was some video files and one audio track. how do i do this again or the right way. or is there some crazy alternative way to do this. I prefer using freware software being that I spent most my money on the dvd recorder and dvd burner I will use to make this.
dvd decrypter don't make mpgs. do you mean vob2mpg? or you can use dvd decrypter to make one vob file.
demultiplexing makes separate video and audio files. -
RIP with DVD Decrypter in IFO mode and select NO FILE SPLITTING and you will get one large VOB file.
Then open that VOB file into VideoRedo or MPEG-VCR and edit there. No re-encoding will be done except at the edit points (unless all of your edits are on "I" frames).
In the end you will get a MPEG file that is ready-to-author.
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 08:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
Choppy/ out of sync audio from homevideo to DVD
By dwilson in forum Authoring (DVD)Replies: 1Last Post: 11th Mar 2009, 23:53 -
Making a homevideo more like a theater movie
By qazwsx16 in forum EditingReplies: 12Last Post: 4th Jun 2007, 14:56
