    Nov 2006
    Hi all,
    I'm new here, but not new to PC's. Anyway, I have a Mpeg file of my friends band that was recorded last night.
    I'm trying to find a way that I can scan through the file and actually create individual clips. Such as if I was making individual music videos from it. I would choose a starting point and an ednind point, then save that as 1 file, then do the same for another file, etc.
    I've tried a few programs, but so far I've not had much luck.
    What can I use? Anything?
    Thanks in advance for any help.
  2. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    MVW
    USA
    For that you need a MPEG editor. Some popular ones are VideoReDo and MPEG-VCR. MPEG Video Wizard, mentioned by Epicurus8a is a little more advanced editor. There are also some freeware ones available to the left in 'Tools'. <<<<<< Encoders like TMPEGnc can do some very basic editing, also TMPEGnc DVD Author.
    If you plan to do this often, a standalone editor would be a good investment. If you just want, quick and fairly easy to use, try Windows Movie Maker. It won't output in MPEG, though, so you would have to re-encode.
    There are also some package programs from Ulead and others that come free with some capture cards or similar that may work, or they can be purchased cheaply.
    Most any good editor has a learning curve. But they should all be able to cut out and save clips. You didn't mention what final format you wanted for the clips, so I assumed MPEG.
    And welcome to our forums.
  4. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Don't waste your time on MPEG tools inside the old TMPGEncPlus, you'll get many bugs (like audio out of sync etc.) without using some tricks, especially with VBR MPEG2. TMPG MPEG Editor, VideoReDo and MPEG Video Wizard are the right tools for cut/join editing.
    Feb 2004
    Australia
    The best tool for this job is ulead video studio ... any se version from 8 and on ... you get more for the money ... $15 to $30au in ebay ... no screwups like other programs either ... It's all in one , unlike others mentioned here above .
    Or the freeway :
    Though this process requires a little knowledge and a few tools .
    Vdub
    Notepad
    Batchdemux
    Ifoedit or muxman
    Vobedit
    Bbmpeg
    This is to retain mpeg .
    For vob , the above tools and
    Besweet
    Throw in for full dvd creation and playback
    Dvdauthorgui
    Pgcedit
    The gimp
    Imgburn
    Koolplayer for xp / 2000 (ifoedit for win me , 98se , 98)
    Freedvdcodec
    Ac3 filters
    Sub filters
    Nov 2006
    Thanks for all the replies and help so far.
    I have tried using, VideoRedo, but I think that the only way that is going to work for me, is if I just create and save 1 clip at a time, Then close and re-open the file and create another clip, etc.
    I've also tried windows movie maker, that does not work for me either, nor does Nero vision.
