i understand that only FULL version support AC3 audio
anyone has ANY solution to this problem for those using SE version of ulead videostudio
thank you so much
Demux.
There is plenty of freeware that can go from AC3>WAV>AC3. -
Strip the main title into seperate streams
Convert audio to ac3 using besweet
Reauthor using either ifoedit or muxman
Run pgcedit
Load newly regenerated title
Click and highlight title
Right click it , and choose "import menu" (choose the correct ifo from uleads project folder ... say Y to copy)
Reconnect the dots (nav commands)
Save dvd
Play back , check for nav error's , if so , reload this new title in pgcedit and recheck those commands .
This is just going off the top of my head ... new system ... tools not installed as yet .
If chapters and multiple menu's are involved , it takes a little longer .
Video Quality Measurement Tool (version 1.2 with plugins support)
By DmitriyV in forum Latest Video NewsReplies: 5Last Post: 30th May 2012, 23:40 -
Amateur Question: My DVD9 doesn't support AC3 Audio
By Keziapurrs in forum AudioReplies: 15Last Post: 10th Jul 2011, 20:03 -
VideoStudio 8...will it support "motion jpeg"?
By utamav91 in forum EditingReplies: 0Last Post: 23rd Nov 2010, 00:35 -
Roxio DE 6 does not support AC3...what are my choices?
By utlax18 in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2008, 15:43 -
What version of DivX does Toshiba support?
By supe in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Nov 2007, 21:03
