I have taken a few camcorder tapes i have and recorded them to a DVD with a DVD recorder.
I have been able to get some of the VOB files on the DVD's converted to mp4 format so I can get them into iMovie but not all of them.
I am using ffmpegX 0.0.9x to convert from VOB to MP4.
I have bolded the error in the error message below. I cut this from the error message;
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
Sat Nov 25 19:37:30 EST 2006
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[h261 @ 0x54340c]warning: first frame is no keyframe
Input #0, h261, from '/Users/Eric/Movies/VIDEO_TS/VTS_01_1.VOB':
Duration: N/A, bitrate: N/A
Stream #0.0, 25.00 fps(r): Video: h261, yuv420p, 176x144
Number of stream maps must match number of output streams
The file ends up as a 0k sized file. I am very new to all of this and don't know what to do to fix this.
So, if there is any help that anyone can provide me, it certainly would be appreciated.
Thanks, Eric.
1. ffmpeg seems to think your VOB has H.261 video, instead of MPEG-2 video expected in a VOB file. Never seen that.
2. The bold part is a warning, not an error. The error that is stopping the conversion is the last line: "Number of stream maps must match number of output streams".
3. No audio stream is detected in the log above. Which could be why the previously mentioned error comes up; you can't convert video-only to video + audio.
4. Every clip should always start with a keyframe, which describes the whole frame without dependencies on other frames.
5. Video size is detected as 176x144, which is an oddly small frame size for a DVD recorder, but consistent with H.261 video.
- In case your file is corrupt, try a fresh copy.
Thanks for the info. The original tapes were created on a JVC camcorder, VHS-C format and played to a Panasonic DVD recorder. Maybe that explains the strange size of 176x144!
The strange thing is that there is audio in the original. In the audio section, I tried each audio track with invert mapping on and off and I get the same result. If I de-select encode audio it processes fine. The video is of a trip to Disney and the audio is kind of important. Not sure if you can tell me how to get the audio back.
In the summary section, Audio is set to ac3, 48000HZ, 384 kbps, Video is set to mpeg-1, 352x240, 29.97 fps.
Not sure what to do from here.
E.
The original, that would be the VHS-C tape?Originally Posted by va3eam
Is there audio on the DVD recording, on Panasonic playback?
Is there audio on the DVD disc, when played in Apple DVD Player on your Mac?
Is there audio listed in the ffmpegX summary, on the left side (source format)?
Is there audio when using the Play button in ffmpegX?
That would be the Target format setting? I thought you said you wanted mp4?Originally Posted by va3eam
FFMpeg - warning: first frame is no keyframe - Encode to nearest keyframe?
By mh2011 in forum EditingReplies: 0Last Post: 3rd Nov 2011, 15:58 -
skipping frame! error?
By v0llrath in forum ffmpegX general discussionReplies: 5Last Post: 30th Nov 2009, 14:43 -
Error frame 0 in VirtualDubMod
By rocky12 in forum Newbie / General discussionsReplies: 9Last Post: 5th Aug 2009, 17:06 -
keyframe question
By seanin in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 13:42 -
Cutting AVI files by frame or keyframe?
By squegole in forum EditingReplies: 6Last Post: 1st Jun 2007, 12:25
