How do I rip the music from a DVD menu screen? ANY help would be appreciated!
Can someone help me step by step with this program? I'm lost, it's not saving any of the audio files.
If the Menu Music isn't too long, why not just record it with Audacity or Total recorder?
Open a Menu Vob (as explained by jimmalenko) in DGIndex. Go File->Save Project. At default settings the audio will be saved. You might check to see that Audio->Output Method->Demux All Tracks is checked. I'm pretty sure it is.
Alternatively, using PGCDemux open an IFO for a VTS that contains the menu you want. Tick Domain->Menu, select the menu you want in the drop down box, and "Process".
Ripping Music Videos From DVD
By skywalka in forum DVD RippingReplies: 15Last Post: 17th Apr 2012, 11:27 -
Music in your DVD Menu's with DvdLab Pro
By RickyPinxt in forum Authoring (DVD)Replies: 5Last Post: 8th Apr 2010, 17:45 -
dvd with menu with music
By aruwin in forum Authoring (DVD)Replies: 1Last Post: 8th Jan 2010, 21:58 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Removing menu's music from DVD
By Turbo Sensonic in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2007, 22:22
