ok i new at this so here it goes...
i own a asus v7700 deluxe with the tv box and and a Soundblaster live, i believe all the wires are properly connected (tv box to line in et all). when i use the asus software i can hear the sound allright, but when i capture something to .avi and play it back there is no sound at all?!?!? with virtualdub there is no sound from the getgo!! does anybody know a solution???
to only way i've been able to capture with sound is when i use the microphone connection, but then the sound is pretty distorted!!!!
HELP please........
Open your mixer settings / Volume settings. Check if your Line IN in Recording mode is NOT muted. Adjust sound level as desired. Also MUTE microphone in Recording settings while capturing to prevent external sounds from getting recorded.
thanx, can capture with sound on the asus live application, but virtuadub still refuses to make any sounds on starting it up... no matter i'll just use the asus stuff...
thanx again fot yer help!
Audio trouble from WDTV HD Live
By torrentkid in forum Media Center PC / MediaCentersReplies: 1Last Post: 13th Jul 2010, 09:17 -
Trouble ripping video and/or audio
By dexter30 in forum DVD RippingReplies: 8Last Post: 26th Feb 2010, 12:06 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 05:57 -
Trouble getting video in time with audio
By JayxDee in forum ffmpegX general discussionReplies: 1Last Post: 27th Jul 2008, 09:36 -
Philips DVP3040 Audio Trouble
By devilsknight in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2008, 16:52
