I recently burned several AVI video's to DVD using WinDVD Creator 1 and while viewable the quality is considerably worse then before the burn. I'm guessing I need to convert the AVI's into a different format but I don't know which one would work on standard DVD players and what programs can do the job.
Info:
My DVD players only play standard DVD's.
I am using DVD-RW's.
I've used the program to create DVD backups without issue.
You need to use a dedicated MPEG-2 DVD spec encoder as opposed to a "all-in-one" program because such "all-in-one" programs tend to perform poorly.
1.) What format are your AVI files? In order to help me out in helping you out do this: load the AVI into a program called GSpot and take a screen grab of the results and post it here. If you need help on how to take and post a screen grab then read this link: CLICK HERE
2.) I can tell you right now that you will need to download and install the following programs ... all of which are freeware (as is GSpot):
1.) HCenc
2.) AviSynth
3.) VirtualDubMod
4.) Audacity (although I prefer GoldWave although GoldWave is not freeware it is trailware)
5.) ffmpeggui
Get back with that GSpot screen grab and I'll go into more detail then.
Poor Burning Quality
By CindyLuB in forum DVD RippingReplies: 6Last Post: 17th Jul 2010, 21:41 -
Bad sound quality from avi's to DVD w/both Toast or XiliSoft DVD Creator?
By NoMoPackers in forum MacReplies: 7Last Post: 2nd Apr 2009, 04:57 -
avi to dvd picture poor quality
By dwilson in forum Authoring (DVD)Replies: 2Last Post: 21st Mar 2009, 09:10 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
