This is probably a simple question to ask but I've scoured the web but I just can't seem to find a concrete answer. When I burn a DVD I've used DVD + R and DVD - R media and also RW. Now I've achieved some good results depending on the manufacturer but everyone I play in my DVD Players they all seem to pause or skip at some point. My question is.....if I were to use Dual Layer recordable DVD's would this solve my problems? I mean how do all the movie guru's make a DVD so that it will play on all DVD players irregardless of make or model. What media do they use? What software do they use? etc. Where am I going wrong? Okies dokies thanks for any help.
dvd+rdl wont work better. see our dvd player list for compatibiliy.
If you want something that works on everything you must "press" the disc commercially. -
You didn't mention the type of burner that you are using or the brand of media. Flaky drives and poor media account for most of these problems.
Change the media.
Burn at a slower speed.
Upgrade the firmware.
Replace the burner.
Good luck. -
As baldrick has pointed ... commercially pressed is the only true method that works .
The rest fall into many area's :
Drive used
Fireware revision of unit
Media used - some are rubbish
The player - unit for playback
Not to forget the video streams used for the project :
Improper bitrates ... issue's using mp2 audio (convert to ac3)
For burning , you need to follow the basic rule's :
Dvd-r only ... not all players like other forms .
4x burn max ... media fixation is improved the slower you burn .
4.3gig max fill of capacity ... older players had issue's reading near the rim on the media .
If the media is quality ... burner is highly rated ... rule's where followed , then the final issue is with the playback unit .
Make / model - some are cheap junk
Age - wear and tear device has already been subjected too
Final problem comes down to dl media , and the placement of the layer break point ... it has been suggested as an example for better control .
Dl - second layer contains max 4.3gig , first layer contains remainder .
A bit backward , but because the layer break on the first layer is closer to the center of the media , and not near the outer rim ... any pause experienced will / should not be noticable ... the close to the center of the media on the first layer , the less distance the head need's to travel back .
I personally set the break point in my projects inbetween a specific scene break's ... scene switch's between locations (non transitional between scene's , cut off / cut in) or scene's with complete fadein / fadeout usage of black ... never anywhere else .
Software :
My advice is to use freeware , before anything commercial .
Basic authoring of title from compliant media streams :
Ifoedit + imgburn
For more fuction :
Dvdauthorgui
The gimp + xnview
Besweet
Vobedit
Ifoedit
Bbmpeg
Avisynth + extra dll's
Virtualdub / mod
Visualsubsync
Koolplayer + ac3 filters + freedvdcodec + subtitle filter
Pgcedit + plugins
Vobblanker
Wax2
Blender
Dvdshrink
Super
Commercial : In order of value
Nero burning rom ... limited , but workable .
Ulead video studio ... with some handy extra's , but limited menu design's .
Vegas movie studio / dvd architect studio... more fuctions .
More ... but I dont work with them
Dvdlab ... bugs still exist , work's
Tmpgenc ... bugs as well , work's -
In my experience a decent DVD writer will work with almost any media or software. Changing the other two factors can only ever be a temporary expedient. Sooner or later the DVD writer will have to be changed. I read the feedback reports on this site and eventually plumped for the NEC 3520A which had a 97.5% satisfaction rating at the time.
