say someone overseas makes a dvd and its pal cuz thats how it is in europe...and i were to play it on my US dvd player cuz i live in the US, i cant play it correct? there isn't any region coding on the dvd disc from overseas but the fact is US dvd players dont play pal unless its one of those players that can switch between pal and ntsc. correct ? no?
again there is no region locking on the dvd from overseas, was made by the user so its just a pal formated dvd with no macrovision...and i cannot play it on US dvd players since they are ntsc formatted...correct? please if anyone can give me a detailed explanation....the guy i'm dealin with believes pal can be played on ntsc dvd players, but they can only be played on computers. he keeps forcing the issue that since they are region free meanin no region lockin they should play.
Some US DVD players CAN play both NTSC and PAL, such as Apex DVD players and Lite-On DVD recorders. You can always play the DVD in question on your computer if you have to.
PAL and NTSC are indeed different formats, so they are not playable on most US DVD players. If you could force a NTSC DVD playe to play a PAL DVD there would be no color and the picture would roll.
Don't confuse region coding with format. Region coding does not effect a home made DVD. -
There is already another similar thread to this running. The Region coding and format are 2 completely different things. It is not the Region coding that it preventing you from playing a PAL disc but the format.
The US uses NTSC and is in DVD Region 1. ALL Region 1 countries use NTSC so a DVD player intended to be used in Region 1 will normally only play NTSC
Europe uses PAL and is in Region 2. However, Japan is also in Region 2 and uses NTSC. Consequently, ALL DVD players intended to be used in Region 2 will play both PAL and NTSC.
Consequently, the guy you are dealing with has it the wrong way round. NTSC will play on virtually any machine, PAL will only play on a machine intended to be used in a less inward looking country.
The Region coding is a completely different thing and will have no bearing on it. A US market multi-Region player will play any disc not matter what Region coding it has but only if it is NTSC. A European market multi-Region player will play any disc. -
Originally Posted by Richard_G
thank you, this was the answer i was lookin for...yes i already know the region codin has nothing to do wit it not playin on my dvd player..i kno its because its pal and not ntsc, he just doesn't understand that. but this is what i was lookin for....an explanation...now i can tell him
Will a homemade NTSC dvd play on a PAL player?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 23rd Nov 2010, 03:54 -
Ntsc BluRay players play PAL(region-free) dvdr?
By spiritgumm in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Nov 2009, 18:48 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Converting homemade PAL to NTSC
By Kernos in forum MacReplies: 12Last Post: 18th Jan 2008, 15:48 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 08:31
