Results 1 to 11 of 11
What is the audio format for this file?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Can you use Gspot on the file and post a screenshot?
Dwight
- Herm Albright
If it is a oneoff file the it is possible the file is corrupted.
Codec issue?
Dwight
- Herm Albright
It's alway possible (probable?) that I am mistaken. It was just a thought...
Dwight
- Herm Albright
not move the file tmp dir to upload folder
By velayudham in forum ffmpegX general discussionReplies: 2Last Post: 19th Jan 2012, 17:32 -
Converting a Blu-Ray main move to a DivX file
By flyitfast in forum Blu-ray RippingReplies: 4Last Post: 26th Sep 2010, 15:31 -
Does SVCD2DVD process and burn HD quality DVD from HD .ts file?
By jeemak in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Nov 2008, 22:03 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
The last vts file screws up why?converting xvids?using svcd2dvd!!!
By hacksawman in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 8th Oct 2007, 16:30
