I'm using what I think is the latest version of Gspot, 2.60RC01. With Export set up to append to a fixed text file, I'm seeing incorrect Durations in that text for some of my files. (Bit rates and frame rates too, but that's to be expected.)
I've tested 6 MPGs and 2 were exactly right but 4 were grossly wrong.
Haven't yet tried reverting back to an earlier version to compare.
Anyone else please?
Terry, West Sussex, UK
In further tests I found discrepancies in about 75% of the MPG files I tried. A few got me wondering if there might be some sort of transposition issue. For example, the file Silves2.mpg was shown in GSpot as having a 'Len' of 23.160, as seen here
http://www.terrypin.dial.pipex.com/Images/GspotExportError1.jpg
But its exported version reports 21.360, as seen from this pasted extract:
--- File Information ---
File Name: Silves2.mpg
File Size (in bytes): 16,558,080
--- Container Information ---
Base Type (e.g "AVI"): MPEG (.MPG/.MPEG/.VOB)
Subtype (e.g "OpenDML"):
Interleave (in ms):
Preload (in ms):
Audio alignment("split across interleaves"):
Total System Bitrate (kbps): 10080
Bytes Missing (if any):
Number of Audio Streams: 1
--- Video Information ---
Video Codec Type(e.g. "DIV3"): MPEG2
Video Codec Name(e.g. "DivX 3, Low-Motion"): MPEG-2
Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are Installed
Duration (hh:mm
s): 0:21.360
Frame Count: 14877168
etc
I also emailed the author and if/when I hear back I'll report any conclusions.
BTW, it seems 'Duration' is not as hard a fact as say size in bytes. VirtualDubMod reported slightly different values to GSpot in most cases I tried. But the issue raised here is of course about the inconsistency within GSpot, not its accuracy compared to other MPG-reading software.
Various audio durations to video
By mrcoolekin in forum AudioReplies: 3Last Post: 17th Jun 2012, 19:41 -
GSpot 2.70a - Export to .txt file
By skaleton in forum Newbie / General discussionsReplies: 0Last Post: 11th Nov 2010, 12:49 -
Question about incorrect DVD information given by Gspot
By jimdagys in forum DVD RippingReplies: 2Last Post: 9th Dec 2009, 01:24 -
VOB Files Change Durations!?
By ronsweet2 in forum Newbie / General discussionsReplies: 5Last Post: 6th Jun 2009, 04:09 -
How do I get exact durations?
By bratpop in forum DVD RippingReplies: 7Last Post: 19th Nov 2008, 15:08
