    Nov 2003
    Australia
    Intalled this latest version but after encoding a file to avi it does not play
    I get the message that the file needs a decoder that is not installed.
    Which decoder should I install?
  2. Member SanderMan's Avatar
    Feb 2001
    Netherlands
    You could try ffdshow. It plays most avi files.
    If you don't want to install new codecs vlc media player should work also.
  3. Member ricardouk's Avatar
    Mar 2005
    Portugal
    Doesnt the Xvid codec encode and decode? All you need is the xvid
    I love it when a plan comes together!
    Nov 2003
    Australia
    Yeah that's what I thought it would but doesn't decode apparently. MPC says that the codec is not installed or missing.
    Dec 2004
    Australia
    The Xvid codec encodes and decodes (that's what a codec does) the installer also includes a dshow decoder which is what MPC would use. Only thing I can think of is that you used a different FourCC (than XVID) when you encoded.
    Nov 2003
    Australia
    Problem is that at the time I was using Super to encode from flv to avi and Super does not have a fourcc option (as far as I know) the default setting was mp4.
    Although there is an option to directly set Xvid via the menu.
    VD was accepting Divx encoding but wasn't accepting Xvid don't know why.
