I got an avi, but the sound track has some pops in it. I demux'd using vdubmod, edited with GoldWave, but it doesn't save as AC3, so I saved as WAV. When I remux'd with vdubmod, at the end of the clip there is aboout a half second delay in the sound track. what can I do to avoid this delay? any free s/w to edit AC3? also have Audition 1.5 which doesn't recognize AC3.
thanks
Hi
Is new track you fixed the same length as original?
You said that you fixed some pops. Did you cut them out? If so you shortened the track.
I do not know your software, but if it has a pen tool that you can use to draw on the track, than enlarge the pop(track timeline) and draw wave similar to rest of the track, it will fix it. Pop (seen as high spike)is short so whatever you draw will not be heard in the play.
editing dvd/bluray audio files, dts-hd and ac3
By krohm in forum EditingReplies: 7Last Post: 9th May 2010, 08:31 -
Importing files with AC3 sound into editing software
By jeanpave in forum Video ConversionReplies: 10Last Post: 21st Apr 2010, 01:55 -
Editing & joining AC3 tracks
By carlmart in forum EditingReplies: 1Last Post: 18th Apr 2010, 12:06 -
A Tool for editing AC3 without recompress? (like mp3DirectCut)
By CactusMan in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 13:28 -
Editing ac3 Audio in Premiere
By tSu in forum EditingReplies: 5Last Post: 10th Nov 2007, 20:32
