Ok so my project is goign well but now i want to add a 4 screen split using the tutorial i found here
[img]http://www.tutorialized.com/tutorial/4-Split-Screen/12614
[/img] my problem is that i need the 4 videos to work off of eachother. Meaning i want 1 sequence of me getting off a chair to remain for the lenght of the video, so basically the empty chair i got off of would last for the next 40 secs. the empty chair would be the remaining image.
The only idea i had was to make a tiff or bitmap image of the last frame, add it to my video and adjust the lenght to make it 40 secs.
In premier is there a way to just make that part of the video last the 40 secs.
Thanks for the help
Results 1 to 1 of 1
LilemanGuest
Adobe Premier CS4 - How do I split a wav ?
By bx510 in forum EditingReplies: 1Last Post: 21st Aug 2010, 09:08 -
Problems with Adobe Premier Elements
By jeffprice74 in forum EditingReplies: 4Last Post: 21st Jun 2008, 10:24 -
Adobe Premier Elements 4
By Jedi5 in forum Newbie / General discussionsReplies: 0Last Post: 8th May 2008, 22:01 -
Adobe premier cs3
By m baqar in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2008, 21:55 -
problem with my adobe premier 7.0
By pondleaping in forum EditingReplies: 4Last Post: 13th May 2007, 10:29
