    Oct 2005
    Germany
    Hi,
    I have a little problem with Procoder 2 - at last the software which encodes 50 mov trailers without problems. Almost without problems: contains the mov a AAC 5.1 audio stream, it says "QT Reader: General Error". Why is this? At least it could only convert the video stream or something like that... I'm so frustrated!
    bekay
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    make sure you have the latest qt installed ... other than that ... itmight still not work ... check in the canopus procoder forum (reg required)
    Nov 2005
    does procoder allows mkv input
    Oct 2005
    Germany
    Yeah latest version installed... you can dot it, if you export the audio track with qt and then strip the audio stream. but of course: that costs time.
