    Sep 2006
    I have a AVI file, which has too much blue color in it. Which software I can use it to fix that?
    moved to another forum, nobody likes me here...
    USA
    I'd use VirtualDub and a RGB filter. You can find one at http://neuron2.net/ Another easy filter to use which includes white balance, color correction, contrast, brightness and a few more is the White Balance filter. But for specific color control the RGB is probably better.
    Sep 2006
    Is RGB included in VD or I have to d/l it?
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    He's a liar and a murderer, and I say that with all due respect.
    Sep 2006
    thanx
    Sep 2006
    I have problems fixing this color. Is there any way to find out what are correct numbers?
  7. Member grannyGeek's Avatar
    Apr 2006
    Land of the Rising Sun
    Maybe you would like to try out one of these VirtualDub filters
    ColorMill and RGB Equalizer available at these links
    http://fdump.narod.ru/
    http://user.rol.ru/~eugekhor/
    Both work by simply moving sliders to adjust color channels, brightness, contrast, etc.
    Colormill is a favorite of mine, I recommend it highly.
    grannyGeek ~~
    Antique Newbie
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    There is also an issue with certain versions of Xvid causing blue tinted playback. Perhaps you just need to update a codec.
    Read my blog here.
