I have two dvds that I would like to combine into one.
One dvd is 3.7 gigs and the other is 4.1 gigs. How could I combined the two
DVDs into one with DVD Shrink. Or should I use a different program to do so.
I also have two dvd drives if that is any help for the process but I think only one is a DVD recorder but maybe both are.
If you want titles only (no menus) then you should be able to use re-author mode in DVDShrink and drag all titles you wish to keep into the reauthor window. You could then re-author your own menus in something like TMPGEnc DVD Author. However, a much easier one-click method that will retain everything is to use DVDRemake. It truly is as simple as loading both source DVDs as assets, and then going to Tools > Merge DVDs. This places a top menu with simple buttons to each DVD's Main Menu.
If in doubt, Google it.
convert and merge
By maichrcol in forum Video ConversionReplies: 3Last Post: 18th Dec 2009, 16:52 -
Easiest Program To Merge Two DVDs Without Interruption
By V Bot in forum DVD RippingReplies: 7Last Post: 11th Sep 2009, 22:27 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
How to merge...???
By OzarkBaby in forum Newbie / General discussionsReplies: 1Last Post: 14th Jan 2008, 11:28 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
