I capture a movie from a VHS tape that is of course 4x3.
I crop it with vdub as the movie have hardcoded black bars on top and bottom
it looks close to 16:9 now and I save it as 720x480 Huffy.
But other programs thinks this files aspect ratio is 3:2
If I try to author a DVD with NERO Vision as a 16:9 it will add big bars on the side
as this program think the files is a 3:2 source.
So how do you tell Nero Vision that the source is 16:9?
Or how to you change the aspect ratio in a AVI file like Huffy?
Use a real encoder. NeroVision is rubbish.
Read my blog here.
The easiest method with that program is probably just encode the mpeg2 files as 4:3 (without adding the black bars) then use DVD Patcher to change the header. It can make them 16:9 easily. I would patch 'copies' of your originals leaving them unaltered (just in case). lolOriginally Posted by tonyp12
Other than that... Use Tmpgenc.
As far as aspect ratios and Huffy goes the latest version of VirtualDub, v1.7.0, has a unique resize filter with all the aspect ratio settings needed but for the life of me I could never get it to work properly.
Good luck.
How do I change the aspect ratio in an MPEG file without........
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 27th Oct 2011, 16:24 -
Change the aspect ratio of an m2v MPEG2 file?
By theDruid in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2010, 22:16 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 13:14 -
How to change aspect ratio?
By crt in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 10:49 -
Change/Set aspect ratio in AVI file
By cheerful in forum Newbie / General discussionsReplies: 9Last Post: 7th May 2007, 17:28
