Hi,
I've recently started buying other region DVDs (I live in R1), and I own the above mentioned portable DVD player. I've already read the hack that's listed here, and I also read the post from earlier this month indicating that the hack worked for that person. Having said that, I'm at a complete loss. I use the remote control and follow the instructions *to the letter*, but I can't get the hack to work.
1 Power on
2 Press SETUP
3 Enter the Preferences menu
4 Press 224455
5 Press LEFT, DOWN
6 Press the button for the region you want (10/0 = multi- region)
7 Press SETUP
I get as far as the entering the Preferences menu, but when I try to enter in the numbers "224455", nothing happens - and as a result, nothing else further down the list works either. If *anyone* can help with this, I'd be eternally grateful.
Thanks.
You may also have a newer version of the player and all of the codes are now locked. If the player was meant to be region free, you wouldn't need a hack.
Google is your Friend
LG RC299 region hack gone wrong
By presley23 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 18th Apr 2010, 19:18 -
Help finding region code hack for magnavox nb500mg1f
By jswatkins in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Dec 2009, 22:09 -
Region free hack for a Magnavox NB530MGX player
By robins80 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Oct 2009, 09:54 -
Magnavox MPD845 Portable DVD Player
By Kat9119 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Mar 2008, 14:11 -
Region hack for Magnavox MWD200G?
By Gooty in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Feb 2008, 10:26
