I can capture from analogue tape to Pinnacle Studio, edit and add effects. The file is in AVI. When I check the file everything is fine. But when Pinnacle converts the file to be DVD compliant I get small glitches in the final video.
Is there a standalone program that will let me just author and convert the file I get from Pinnacle.
Thanks -
didikai,
i just saw your post.....im looking for exactly the same solution......am also using pinnacle studio to capture from vhs tapes, and want another standalone programme to encode and burn the files to dvd (because pinnacle takes hourrrrrrrrrrrrrrs)......if you happen to find a good solution, please email me gary@pcsavers.co.za and likewise, if you send me your email address, i will do the same if i find a good solution -
Originally Posted by didikai
Adobe Encore DVD
DVD Architect
or more basic ones like
NeroVision
ConvertXtoDVD
Ulead DVD Moviefactory
Pinnacle studio 14 problem with DVD export
By Alternator in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2010, 21:22 -
Pinnacle Studio: Pan and Zoom/Rendering Problem
By ashleyvideogirl in forum EditingReplies: 0Last Post: 18th Jan 2009, 03:30 -
Pinnacle Studio 11 - Problem with cropping video
By mjkamish in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2008, 16:51 -
Trying to edit avi in Pinnacle Studio: PROBLEM!
By L3Wi5 in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2008, 12:09 -
Pinnacle studio program stability problem
By SearchQuality in forum Newbie / General discussionsReplies: 4Last Post: 14th Nov 2007, 20:06
