Hi
I have the Q35/781 Philips DVD player and im confused about the sound configuration.
I already downloaded the model users manual, but is not the same one.
My DVD plyr in the rear have the following conectors:
Video: Y/Pb/Pr , S-Video and Composite
Audio: L-R , Optical , Coaxial and here is my doubt..... has Fr Fl Sr Sl SW C, all the conectors for 5.1 audio set up.
My DVD have DTS and ProLogic, and Prog Scan
My question is when i connect a speaker in the FR or any of those conectors, doesnt sound loud, this let me know that this audio outputs, are not amplified....but then WHAT IS THE PURPOSE of this Audio Outputs, how can i get the major benefit out of them?????????![]()
Thanks in advance.
They are provided for amplifiers/preamplifiers that utilize those connectors (or for self powered speakers).
You most likely just need the optical or coaxial digital input.Google is your Friend
SONY S370 BLU RAY Plyr NOT PLAYING SUBTITILES FOR MP4 format from USB
By Raghavendran in forum SubtitleReplies: 8Last Post: 31st Aug 2013, 13:54 -
DVP5992 Philips sound issue
By udidwht in forum DVD & Blu-ray PlayersReplies: 11Last Post: 21st Nov 2010, 22:58 -
Philips 5982 - Problem with HDMI sound
By Lawbringer in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Jun 2008, 13:32 -
Stereo sound on Philips 3595 (ie through amp)?
By Trollheart in forum DVD & Blu-ray RecordersReplies: 14Last Post: 17th Mar 2008, 12:53 -
sony DVD Recorder and Satellite Tuner Configuration
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 1st Oct 2007, 14:05
