I have a avi clip and when I open up WMP at the bottom is says opening media then error downloading codecs and the video plays but with no sound.
I thought it was just a dodgy file but it happened to a couple more clips that I got a few weeks ago which I know had sound.
Is this a media player of file problem because I wanted to burn it to a vcd so im not bothered about watching it on my laptop?
any ideas on what I can do to get the codecs or whatever?
ps. the clip is from limewire and im using WMP 8
Drop the video into Gspot 2.60 and see what codec it needs. Then you should be able to find it in 'Tools' to the left. Alternately, download VLC Media Player and see if it works. If so, it probably is a codec problem. VLC uses it's own codecs.
i have Gspot open with but how do I find out what it needs?
it finished on this - http://img216.imageshack.us/img216/8228/screenhunter001kl6.jpg -
from my screenshot it says the video codecs are not installed and the audio codecs are but there is video playback but no sound, i dont get it.
I installed this https://www.videohelp.com/tools?tool=XviD_Codec and have no ideo how to use it and there still is no sound. -
It's hard sometimes to figure out what WMP is doing.
The video and audio should play back with no problems. MP3 audio codecs should already be installed as part of the system. Did you try VLC? I'm guessing it will work, unless the video itself is damaged. I don't use WMP, so I'm not much help with it.
With Gspot, you can use the bottom part of the page for 'Proposed Codec Solutions and Tests' and see what your computer is doing to try to play the file, both the video and audio part. That part can get a little complex if you have more than one audio codec that can render the audio or video. With the video, it may be using a Divx codec instead of the Xvid one, that might explain why it says the codec is not there, but still plays. -
Since it plays fine, then the file appears to be intact. Whether or not it works after conversion will depend on the tools used.
Google is your Friend -
Hey, I'm new on this forum and so far have been unable to get a post out - so if anyone gets this, please let hear back.
I have downloaded Media Player Classic onto my Windows 7 laptop (high end thing!) and get NO sound on any playback with Media Player.
Any suggestions?
parke sprague (parkesprag@aol.com)
Media Player Classic No Sound
By jrank001 in forum Software PlayingReplies: 19Last Post: 20th Jun 2014, 05:07 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
No 5.1 sound in Media Player Classic
By Dozza in forum AudioReplies: 0Last Post: 19th Mar 2010, 00:40 -
WD TV Media player and 2.1 surround sound?
By gregtherotter in forum Video ConversionReplies: 1Last Post: 7th Oct 2009, 17:18 -
help with no sound with DVD's using Media Player 11.
By Bamahusker in forum Newbie / General discussionsReplies: 6Last Post: 1st Jul 2007, 14:38
