    Nov 2006
    Ok so I just bought a new DVD player that can also play DivX, Magnavox MWD7006. It was on sale for $40 so I thought I might as well pick it up. It works great in terms or recognizing media, it can play all AVI files I threw at it so far. I have one problem though, some of the AVI files are kind of zoomed out, they have bigger letterboxes than they should have, they have a letterbox on all 4 sides. So the problem is, when I click zoom, it zooms in, but too much so that half the movie is outsize of the zoom, but when I zoom back out it goes back to having a letterbox on every side.
    Any ideas on how to fix this? It happens only on select AVIs, my guess is they haven't been encoded right.
    maybe try change the avi aspect ratio with mpeg4 modifier.
    and this is not any dvd authoring. moving you.
    Nov 2006
    Didn't work, I noticed that it only happens to files that are encoded with DivX, Xvid works just fine. So any other suggestions except for having the re-encode files into Xvid?
    Nov 2006
    I have a question about that aspect ratio changer, which option do I change so that the aspect ratio changes, cause no matter what I do, the video still stays 580/460 (example).
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I believe resoution stays the same, you are only telling the player how to display the video.
    For instance, if you have 4:3 source with an aspect ratio of 4:3, it will fill the screen on a standard TV. If you change the AR to 16:9, you will get black bars top/bottom on a standard TV.
    Google is your Friend
