    Nov 2006
    Hi Guys
    I have posted this in the newbie forum but think I will Have a better chance here.
    Just trying to convert a avi file with SVCD2DVD and got as far as the burn when I got the following report.
    Version: SVCD2DVD 2.1
    Build: 2.1.2474.30185
    Type: System.NullReferenceException
    Source: SVCD2DVD
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.x3b9d134dac76e 484(xece14591aa1abb99 x50afe96f7df19242, xcbd1127f90d7945f x3146d638ec378671)
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
  2. What program are you using to burn?
    Can you post your log file?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Nov 2006
    Hi Jikchung
    Thank's for getting back to me.
    I have Nero burner to burn the files but it didn't get that far.
    Looking at the log there appeared to be a problem locating the avi file. I had previously saved this file on a disc and was asking SVCD2DVD to take it from my dvd drive. Should I only convert files that are on my hard drive?
    After seeing this in the log I tried an avi file that was on my hard drive and it actually made a DVD from it, although it did keep sticking on my DVD. I will try again using a +DVD instead of a -DVD like the one I used.
  4. Yes, use AVI files that are on a hard disk. SVCD2DVD places the created MPG file in the same folder as the AVI then authors from there.
    If you have any other burning issues try ImgBurn instead of nero.
    Dwight
    - Herm Albright
    Nov 2006
    Thank's again for reply.
    Have managed a great DVD from AVI having used a DVD+ which suits my DVD player better.
