Hi all,
I'm looking for a standalone DVR with at least 160 GB HDD that imposes no restrictions on the material copied from DVD to HDD. I have a large collection of DivX files recorded on DVD discs and I would like to be able to watch them straight from the DVD (with subtitles) and copy some of them onto the HDD and still be able to watch them. This also applies to Xvid, MP3 and WMA files.
A nice option would be a USB 2.0 connection to an external storage and a SD card reader.
Is there such a DVR? Or something close to it?
Thanx
Results 1 to 12 of 12
A home theater PC, that's as close as it gets
Panasonic DMR-ES45VS, keep those discs a burnin' -
Closest thing I can come up with is the Philips 5960 - it is just a DVD player. It plays Divx via disc and also has a USB port that allows you to hook up an external hard drive. You could move what you want to your hard drive via your PC and then play them using the Philips 5960. Just a thought.
It is discussed here:
https://forum.videohelp.com/viewtopic.php?t=301465 -
I think I found something very close to what I want:
LG RH200MH Multi Region Super Multi DVD Recorder (DVD+R Double Layer) + 250GB HDD + HDMI + 14-in-2 Memory Card Slot
http://www.digital-point.co.uk/model-2605.html
Any opinions?
Yesterday I found out that there is DVD-HR745 by Samsung. It looks like perfect choice for me. But where is it? I can't even find it on Samsung website! -
I have the Philips DVP5960 with a 500GB Lacie Porsche external HDD hooked up to the USB port. I have about 200 DivX 5 and 50 DivX 6 movies on the drive so far - most converted with 700 MB file size limit in Dr DivX/DivX Converter, a few captured at Home Theater res with DivX 6.0.2.5 CODEC on ATI AIW in MMC 8.1. The movies play well and look fine. External drive is nice as it is easy to move from PC to player, much easier than built in HDD. The DVP5960 upconverts also. XVids play OK also but I don't have many of them. The price is definitely right - $69 for the DVP5960 from Circuit City, and got black fri deal on Lacie 500GB for $229 with tax and all fees. Note there are a few specifics about reading files from the external HDD to know though:
External drive must be FAT32 (not a problem since most new drives are formatted FAT32 from factory). Filenames are displayed 8.3 on the GUI, like old M$ DOS.
Only a single level of folders appears to work on movies (e.g., westerns folder containing movies Once Upon A Time In The West, The Good The Bad And The Ugly etc) read from external HDD, but two levels work from DVD.
Again, single level of folders for MP3s read from HDD, and only 848 files will be recognized. Again can have two (maybe 3) levels of folders for MP3s burned on DVDs though. Easier for me to plug up my creative zen to the stereo as I have 12K+ files and not even put MP3s on the HDD. Maybe could split em up in folders though.
Overall though very happy with the combo. Nice to have hundreds of movies at my fingertips that I can pick from a menu that easily play on my HDTV. Simple to capture in DivX 6 on PC, copy file to ext HDD, watch on HDTV. -
I have yet to see a standalone HDD/DVD Recorder that will let you transfer "foreign" video format files to its HDD. By "foreign" I mean in a format that it could not have created itself (or a similar compatible model).Originally Posted by witekc
Well, Samsung DVD-HR745 supposedly lets you copy anything it can play both ways DVD<->HDD. It applies also to MP3 and DivX which it cannot create.Originally Posted by bobkart
I believe you will find in that case that the copy from DVD to HDD of DivX material (my statement does not address MP3) will be done in real-time by simply playing back the DivX and re-encoding to a format that it has thus created itself (namely, MPEG2). It will not be a bit-for-bit copy. If this is not the case then this would be the first example of such a capability, and I would indeed be interested in hearing about it.Originally Posted by witekc
Well, I have just checked that on Liteon LVW-5025GHC+ (my dad owns one). It copies DivX material bit by bit in any direction. It does not recompress it.Originally Posted by bobkart
No, no editing. You can just add/change the title.Originally Posted by bobkart
Divx is tough enough to edit using the appropriate editing program on a PC. I can't imagine it being possible on a DVD recorder in this case.
Car DVD Player with MPEG2 via USB HDD???
By dargloss02 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Nov 2011, 00:30 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
DVD Player with USB HDD (Non external Power) support
By fayewolf in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jan 2009, 22:10 -
how to make copy of system hdd to another bigger hdd and replace
By deejay.2001 in forum ComputerReplies: 6Last Post: 28th May 2008, 19:29 -
HDD Recorder with USB and Ethernet ports, that also plays DivX files?
By Dr_trout in forum DVD & Blu-ray RecordersReplies: 4Last Post: 20th Jul 2007, 14:59
