Nero 5551/5564; XP pro 2600; SONY CRX-175A1
I can burn data CD but not DV footage VCD.
MPGs to be feed to Nero are all VCD2.0 compliant and previously work on my ME/ W2k system and older CD Writers.
What exactly is your problem? Error messages? etc.
You need to provide more details.
Regards.
Michael Tam
w: Morsels of Evidence -
Actually, I read his question as more of a statement. NERO does do DATA CD's, and really doesn't do VIDEO very well. Instead of trying to get NERO to work, I would pick a different program for video.
That said, yes more information is needed, since it sounds like you're encoding from a format TO VCD, which opens up all the problems with encoding as well as the problems authoring to disk...
By "DV"... you mean off a DV video camera? Or just any digital capture off a computer? (AVI, MPG, QT) -
I certainly disagree with "homerpez".
I find Nero quite good, like a lot of VCDhelp visitors. -
Nero is adequate for simple multitrack VCDs but nothing else.
If you want more complex VCD structures (e.g., menus, chapters, etc.) you will need to use something else (e.g., VCDImager). And yes, I know that Nero can do menus but Nero authors still menus incorrectly and don't work on many players.
Regards.Michael Tam
Sharing PC data in TV / Blu-ray doesn't work
By JN in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Feb 2011, 10:12 -
Will A DVD Data Disc Work On Mac As Well As PC?
By blazin-j in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2010, 09:52 -
data storage work out?
By Mr anderson in forum ComputerReplies: 1Last Post: 2nd Mar 2010, 07:35 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Nero Help with Data Tracks
By KnucklesNilan in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 10:06
