TMPGEncPlus is 4 times slower (per pass) than CCE, TMPGEncXpress (my second choice after CCE) - just twice.
The only encoder that might compete with CCE in terms of quality is Procoder. I like TMPGenc and it is a very good value for the money, but it's not as good as CCE. Maybe you can search on the internet and find out if others are having similar problems. I've had some issues with CCE on AMD systems, but I did some research and got some helpful hints. My problems had nothing to do with AMD but were actually caused by other things, such as motherboard overheating.
I have found CCE to be very stable, and only ever gives me problems when it is my error. The only reports I have seen regarding real instability with CCE could all be traced back to the use of unofficial licensing methods (read warez patches).
Assuming you have paid for CCE, your first port of call should be to make sure you have the latest patches, and then their support line.Read my blog here.
Alternate download locations
By teamsleep in forum ffmpegX general discussionReplies: 7Last Post: 22nd Apr 2012, 05:24 -
By MGadAllah in forum LinuxReplies: 1Last Post: 6th Nov 2011, 02:17 -
Free AMCAP Alternate?
By Mickz in forum Capturing and VCRReplies: 8Last Post: 4th Aug 2011, 21:13 -
editing with alternate scenes and audio
By }{eywood in forum Authoring (DVD)Replies: 18Last Post: 17th Feb 2011, 03:23 -
Alternate format other than DV.
By cowmix in forum Capturing and VCRReplies: 13Last Post: 14th Sep 2009, 23:21
