I need help on using alltoavi to get .mkv to .avi. I'm really new at this so i'm having lots of problems -.-'' thanks!![]()
Results 1 to 15 of 15
I've gotten to the conversoin part already but i'm not so sure if i'm doing it right. After converting i have like 4 files. Am i suppose to use the alltoavi batch or something to put them together? is it like alltoavi converts it and the alltoavi batcher puts them together? If so, can someone help me by giving me a step-by-step for that? I tried it and got confused...
If it is a CBR MP3 file, open the avi file in virtualdubmod and go streams -> stream List. Click add, browse for the mp3 file and click OK, OK. Go File -> Save As. Make sure you are in Direct Stream Processing mode, put in a file name and save. You should now have an avi file with audio track ready to play.
Read my blog here.
wait.. once i get an avi file with audio track that means that all the 4 files r combined into one? or i need to use something else to put them together?
the files r not at 1 avi file. you said open the avi file? they r split apart and when i try opening the mvk file these warnings come out. is that suppose to happen?
hm.. i'm thinking i messed something up -.-'' can you tell me the steps on using alltoavi to make mkv to avi and formating it a 1 file avi? when i used alltoavi i got multiple files. i'm not quite wure if i'm suppose to get thet
If you actually answer my questions, I can probably tell you. Lets start again.
You have run all to avi and now have a video file, an MP3 audio file an MKV file (which I assume is your original) and an AVC file. Is this correct so far ?
What is the video file ? (extension, what does g-spot say about it ?)
All you need is the video and audio stream from the MKV file. If you now have these files, it is simply a matter of actually following the instructions I gave earlier about virtualdub to put them together.
But until you give me real details, I can't give you much more advice.Read my blog here.
virtualdub gives me all these warnings about the frames -.-'' oh well.. i'll just keep it to mkv then
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can you set alltoavi to produce a single AVI from multiple VOBs?
By benvid in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2008, 12:25 -
Trouble converting OGM to AVI in AllToAVI
By m93 in forum Video ConversionReplies: 8Last Post: 21st Jul 2008, 19:21 -
vob to avi using alltoavi (problem)
By anlaoch in forum Video ConversionReplies: 5Last Post: 22nd May 2008, 18:54 -
DVD to avi with alltoavi
By hilario in forum Video ConversionReplies: 8Last Post: 10th Jan 2008, 03:50
