hello im new to capturing got 2 capturing devices one sound cable plugged into pc line in the other plugged into the microphone plug when capturing i get sound probem i get the audio of just one on the devices in both captured videos (i get the audio of the video source wich i stat recording in second in both the cptued videos ) how can i capture with the two devices without having this sound problem pls help really important thanks if somebody didn't undertans when i meant i'll try to exlain more thankss
Results 1 to 11 of 11
Use a USB sound card for the second source or a USB capture card? An audio mixer?
A standard soundcard cannot record separately from the mic and line inputs.
You must have a second soundcard or use a capture device that also captures the sound.
What kind of video capture do you have?John Miller -
Look into buying a Hauppauge WinTV PVR 250 or a Hauppauge WinTV PVR 350 (either model will work well).
This is a capture card that does MPEG-1/MPEG-2 hardware capture with audio. In short the card does all the processing and sends the MPEG file to your HDD.
It is possible to put 2 or more of these in a single computer and capture from each device so that you can record 2 or more difference programs at once.
It helps if you have a 2nd physical HDD that is very fast. In other words try not to capture to the boot HDD (the one with Windows installed on it).
Does this mean that two instances of WinTV can run concurrently?
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card -
Originally Posted by jmkeuning
But I know at least one person on here said he was running two and one of the hardware sites (Tom's Hardware or that other one that starts with an "A" I think) did a test where they had ... if I recall correctly ... 5 running in one machine.
So yeah I guess you can run two instances of WinTV 2k.
http://www.snapstream.com/Community/Articles/medusa/default.asp -
thank youo all guys for your answers got an external usb capture device and an internal capture card so is it possible to capture with bith devices at once really need your help thanks
Originally Posted by kingking
However it sounds like the internal capture card you have now does not do full hardware encoding type captures meaning when you capture with it you are probably getting very high CPU usage when using it.
So trying to use that while also capturing with another device (even if that other device does Full hardware encoding type captures) is a recipe for disaster.
Originally Posted by kingkingJohn Miller
XP
600GB
2G
Reliable USB capture devices?
By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 19:32 -
Anyone have experience with these capture devices?
By Supreme2k in forum Capturing and VCRReplies: 2Last Post: 18th May 2010, 08:58 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 15:04 -
Any better capture devices than Plextor ConvertX tv402u?
By Heineken77 in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2008, 16:15 -
DivX and MPEG2 capture devices
By Arcturus in forum Capturing and VCRReplies: 18Last Post: 24th Aug 2007, 23:49
