I'm trying to understand this whole MPEG-4 thang...:
- what's the difference between .MP4 and .M4V files?
- which one does the video iPod use and which one does the PSP use?
- is H.264 a thing of .MP4 (or .M4V) files like DivX and XviD are things of .AVI?
- is there a difference between DivX/XviD, MPEG-4 and these .MP4 and .M4V files?
check out the glossary on this website:
https://www.videohelp.com/glossary
has many defintions for youDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
In terms of MPEG-4 an m4v file is the extension for raw MPEG-4 Part 2 video stream. In apple terms it is just a renamed mp4. mp4 is the only official extension. m4a, m4v, m4p, etc. were made up by Apple.
iPod and PSP both use mp4, although you may require some custom Atoms (I read somewhere that the PSP doesn't any more, but iTunes does now to upload 640x480 AVC encodes).
You can store H.264 streams in mp4 or many other containers (including avi). The extension for a raw stream (equiv of m4v) would be .264. Xvid and DivX can also be stored in mp4.
DivX/Xvid are part 2 of the standard, mp4 is part 14.
Some/All of the above would be covered in the above links.
avi has nothing to do with MPEG-4.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
This External hdd enclosure only confuses the sata vs eSata issue for me
By gll99 in forum ComputerReplies: 13Last Post: 12th Mar 2009, 21:01 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38 -
Home Entertainment setup issues - addition of cable box confuses things
By CodySave in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 12:32
