Hello everyone.
I have a DVD with a few recordings, but it this was recorded by a friend of mine, and he captured publicity and other stuff, so I was wondering if there isn't any software that allows me to make edits to the Vobs. I only want to edit the vobs, nothing else.
It's to complicated to me to convert to Avi (or something like that), to make changes and then convert again to Vobs.
Thanks in advance.
Edit >>> Is this going to affect my quality?
You can copy the vobs to the harddrive and then use something like vob2mpg to get a mpg file out of it. From there you can use editors that work with mpeg and reauthor your completed project.
If you are just editing out commercials or making clips out of it you should not notice any quality loss. It depends on what kind of editing you're doing as to whether or not it will drop in quality. Filters and things like that may introduce some loss - you'd be better off using the original source file if you could get a hold of it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
TDA is not free, but is the fastest and most user friendly solution. There is no quality loss at all using TDA as it does not re-encode the MPEG2 (DVD), it just performs basic editing and re-authoring.
If you need frame accurate editing, look at MPEG Video Wizard. It only re-encodes at the edit point.
help editing DVD / VOBs files
By mariano in forum Newbie / General discussionsReplies: 5Last Post: 7th Apr 2012, 21:01 -
help me go from 3 VOBs to 1 mp4 :) /as posted in EDITING
By infernali in forum Video ConversionReplies: 2Last Post: 6th Jun 2011, 05:01 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29 -
Best Practice for Converting VOBs for Editing -> DVD?
By ehmjay in forum Video ConversionReplies: 4Last Post: 7th Jun 2009, 13:46 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52
