I am trying to extract "snippets" of video w/sound from a number of non-encrypted DVD's with DVD Shrink in reauthor mode and occasionally get an error message that indicates an "invalid DVD structure". These DVD's play fine in my computer using Power DVD. Any ideas?
Also, is there a better software to accomplish what I'm doing? I want to create a hight-quality DVD's from the "snippets".
Results 1 to 9 of 9
Um, don't you really need a video editor to do this? I don't understand how you are planning to get "snippets" with DVD Shrink. As far as video editors go, I'd recommend either MPEGVCR or VideoReDo. Both are excellent.
Since you didn't tell us how these mysterious DVDs were made in the first place, it's impossible to tell what's wrong with them. The fact that Power DVD plays them means nothing. Power DVD can play all sorts of things, such as Windows Media Video files, that might be problematic for standalone DVD players. -
Thanks for responding
I have been using DVD Shrink in reauthor mode. It allows for the graphical selection of start and end points and then writes the resulting DVD folder-type data to your hard drive. I just grab the VOB file and go from there. However, some of the DVD's that I've tried give me the above-mentioned error message and will not allow me to extract the short portion of video and audio.
The DVD's are kind of an odd mix. Most of them are copies of DVD's that I own that I have ripped using whatever software I had at that time. I've been doing this for a few years and I have used several methods, so there may be a little "mystery" involved.
I guess to clarify a bit, I should say that all the DVD's worked fine on my computer, playing as normal DVD's w/menu's etc, and the 2 or so I checked on my stand-alone DVD's worked fine also. They just will not work in reauthor mode in DVD Shrink.
Thanks -
SingSing -
They don't appear dirty but I will give that a try...... thanks. -
Yes, it can also be used to take the whole or pieces of 1->many DVDs and author them as one DVD.Originally Posted by Markus74
/Mats
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 04:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 04:28 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 20:48 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 21:49 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 08:31
