Does any one have anything positive to say about Nero 7.5.7? Is it stable? Is it time to upgrade from Ultra 6.6 yet?
This site seems to be very positive about it
www.ahead.deCorned beef is now made to a higher standard than at any time in history.
I use 7.57, but I only use it for burning.
Only you can answer that question. If 6.6 does what you want, then it would behoove you to stay with 6.6. You should only upgrade if you have a new drive that is not supported by 6.6 or if there is a new functionality that you want.Originally Posted by hgh
In the end, it is up to you.
Believing yourself to be secure only takes one cracker to dispel your belief.
Do HD-BURN CD made with Nero work in DVD Players...
By Ensign in forum Authoring (DVD)Replies: 5Last Post: 11th Sep 2009, 23:43 -
Will the Nero LiquidTV Tivo remote bundle work on Vista MCE?
By yoda313 in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Nov 2008, 15:53 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
work-arounds for nero alphabetizing mp3 files
By Mustang.VxD in forum AudioReplies: 6Last Post: 9th Jul 2007, 00:54 -
Nero FLAC plugin doens't work
By happydog500 in forum AudioReplies: 0Last Post: 4th Jun 2007, 14:07
