Hi all,
I'm not sure if this is the right place to ask but heres my question... I have been trying to compress all my Fraps videos with no successI can't get the video 100-200MB and keeping the quality for the life of me. Every Video ends up to be 500MB - 800MB+. I would love to make these videos around 150MB+. I used Vdub and Adobe Premiere Elements 3 with Divx and WM9 Codecs.
Here is the recent video I have been working on...
Souce:
12.5gb Fraps movie recorded at 50FPS
6mins 30secs
960x600
No audio
The quality of the Fraps video is as sharp as the game itself.
I added 2 audio tracks on the video when I compressed it and left it at the default speed for them. Wav for Vdub and mp3 for Elements 3. I tried compressing from ranges 400 bitrates to as high as 5k bitrates. It's either the quality is really bad or the file is too big. Here are the setting I use when I compressed:
960x600
Constrained
2-pass
25-30 FPS
What are the settings do you guys prefer to compress with? It's a 6min 30secs video and I just can't seem to a reasonable size![]()
Here are my system specs if it helps:
Athlon 64 X2 4600+
7950Gx2 Gigabyte
1024 Ram
THANKS!
lower the resolution to 480x300 and you will get a vid that is about 20% of the size.
Thanks for the replyOriginally Posted by RabidDog
How will the quality be?
I've seen 7-8 mins clips with 1280x800 3400kbp/s for around 150MB with beautiful quality. I have to drop my resolution to lower the size?
edit: Another question, does it matter how big the source is? Is this what is causing the problem? My source is 12.5gigs big and is this the reason why I can't compress my video down to a reasonable size and keeping the quality? -
960x600 3000kbps 25fps should be around 150 MB and look perfect if the source quality is good. Maybe try XviD instead of DivX. And check the divx forum and doom9 forum for more information.
No the source file size doesn't matter. -
Thanks for the replyOriginally Posted by Baldrick
The source is great. I play WoW with max settings in 1900x1200 resolution. I Fraps at Full size @ 50FPS. The Fraps result is 960x600 12.5gbs several fragmented clips.
Last set up I tried on adobe premiere elements 3 was..
WMV9
Constrained
3000kp/s
4000kp/s peak
keyframes 1-2
Audio unconstrained (default, I think it was 44hz or something like that)
960x600
2-pass
25fps
The results I netted was around 1.7gb - 1.8gbs file. I am not sure what is wrong.
MKV Compression Question
By silentbob417 in forum Newbie / General discussionsReplies: 3Last Post: 28th Mar 2011, 16:56 -
MPEG2 Compression - Question
By b1tbull in forum Video ConversionReplies: 3Last Post: 2nd Jul 2010, 03:14 -
HD Conversion and Compression Question
By GFK2009 in forum Video ConversionReplies: 5Last Post: 30th Apr 2009, 17:03 -
Quick compression size question.
By capman21 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2008, 20:35 -
Question about Compression ratio
By Sean-- in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2007, 11:30
