  1. Hi,
    I've been looking everywhere for something to capture video in high-def while I'm playing my xbox 360.
    As I understand, it's only possible with a dvhs recorder, but what about capture cards for the computer?
    I'm not 100% sure that the xbox delivers digital output (I don't have much experience in that area), but it can deliver HDTV quality up to 1080i.
    Doesn't any pci capture devices have component in so I can record this?
    I tried to buy a component -> scart adapter to use on my dvd recorder, but I didn't realise that it just had 525i or something.
    Edit:
    Forgot to mention that I'll be only using it to record xbox 360 video so it just needs to have component in, and not cost more than $800.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by Eple
    Hi,
    Edit:
    Xbox360 games are authored up to 1280x720p
    HD output options are
    Analog component YPbPr (480i, 480p, 720p, 1080i*)
    VGA - progressive computer resolutions
    (with XBox VGA adapter cable)
    * 640 x 480
    * 848 x 480
    * 1024 x 768
    * 1280 x 720 (equivalent to 720p)
    * 1280 x 768
    * 1280 x 1024
    * 1360 x 768 (typical resolution for wide screen LCD -TV)
    Good luck recording from either. No consumer level capture cards exist. Analog component to D-VHS should work.
    *1080i is upscaled from 720p.
    Feb 2007
    Because of an fcc ruling about digital capture cards it is currently illegal to make one of theses cards in the US. Something that may be a good solution is a dvd record like the ones found at walmart for near $100. These recorders have hi-def markings but im not familiar with the workings of the systems. At very least it should be able to make copies at dvd quality.
    check this out http://www.avsforum.com/avs-vb/showthread.php?t=660474&page=5&pp=30[/url]
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    not true -- there are several digital capture cards around -- in fact many for SDI and a few for HDMI (most of which are made in the USA)
    like the blackmagic hdmi capture card for 250$ for example .....
    and you can get a component to HDMI converter for another 200$ http://www.gefen.com/kvm/product.jsp?prod_id=3569
    or just get a component HD capture card - though the above option is cheaper slightly ...
