Results 1 to 10 of 10
  1. Any idea why it would suddenly start doing this? I am running Windows XP. I don't think I changed the settings at all and I still have plenty of hard drive space. I am saving the files to an extra hard drive ("F") and it has been working fine until today. When I save to my main drive ("C") it still works but that drive is pretty full and I want to use the D drive for storage. HEEEELLLLPPP!
    Apr 2004
    Miskatonic U
    How big are the files ? If you upgraded from Windows 98 to XP, did you convert all your drives to NTFS, or leave some as FAT32 ? if you didn't convert them all to NTFS then you have a 4GB file size limit on those drives. I suspect C: has been reformatted or converted to NTFS, but F is still FAT32.
    Read my blog here.
  3. I think you're right. All the other discs were just under 4 GB and the last 2, the ones that wouldn't burn, were exactly 4 GB. My computer (running XP) is new but the storage drive was transferred by "Geek Squad" from my old comp which ran Windows 98. I wonder if there's an easy way to continue using that drive for storage of discs over 4 GB as iso files? At least I know what the problem is now. Thanx for the help and the quick response too!
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Sure! Just convert it to NTFS. XP has a tool for that purpose.
    Just go to the Command Prompt and execute the command:
    C:\> CONVERT  F:  /fs:ntfs
    if F: is the drive with FAT32
    If the data on F: is precious, I suggest a backup, but all data is (should be) preserved.
    /Mats
  5. Thanx, I'll give it a try. I am a bit leery because there's a lot stored on that drive and backing it up properly might take awhile. For now I think I'll just work around it somehow. Thanx again for your help!
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    FWIW I have used the command line as stated by mats dozens of times now with no ill-effects. Call me flippant, but I do it without backing up these days.
    If in doubt, Google it.
    Apr 2004
    Miskatonic U
    The only issue I find with FAT to NTSC conversions is the fragmentation afterwards. Run a defrag at your earliest convenience after converting.
    Read my blog here.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by guns1inger
    FAT to NTSC
  9. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Me too. Actually seems to do what it promises to.
    /Mats
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    My player won't play FAT discs, so I have to convert
    (walks away mumbling about the smart-arses in the forum)
    Read my blog here.
