Results 1 to 20 of 20
Thread: Converting audio cd files to mp3
  1. #1
    Member
    Nov 2003
    USA
    Posts
    997
    I know Nero Burning Rom 6.0 has the capability to convert mp3 to audio files. What about the reverse? I have an audio cd and I want to rip it to convert to mp3. Can I use Nero Burning Rom 6.0?
    Member
    Nov 2003
    USA
    Posts
    997
    mat. does my existing nero have that capability? i wonder if windows media player works too??
    Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Posts
    13,177
    WMP does, but I think only to wma? (May be wrong on that point). But why use inferior tools when the best are available for free? Nothing beats EAC when it comes to ripping CDs.
    /Mats
    Member
    Nov 2003
    USA
    Posts
    997
    eac is just better quality? whats the difference b/t wma and mp3? soundwise
    Member
    Apr 2004
    England,UK
    Posts
    586
    EAC just rips to MP3 and it doesn't have much effect on the quality of the MP3,apart from that it can rip slightly scratched/defective CD's successfully and near "Exact" using its re-reading capabilities and offsets ect...The quality of the MP3 depends on the codec and settings.EAC is no doubt the best audio CD ripper you can get.
    MP3 using the Lame MP3 codec (GET v3.97 NOT alpha versions unless you want to test)to encode,kicks WMA ass.The quality is very good as the Lame developers have continuously improved it over the years.
    Look here for a simple tutorial to get you started.
    ..and:
    http://www.hydrogenaudio.org/forums/index.php?showtopic=28124
    for the command line settings.
    If you have other formats which you wish to convert to MP3 using Lame then try foobar2000 which is an audio player which can also convert formats or even easier (But you need to pay!) dBpowerAMP Music Converter
    ~Luke~
    VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Posts
    15,921
    CDEX is free and quite simple to use.
    If in doubt, Google it.
    Member olyteddy's Avatar
    Dec 2005
    Posts
    1,251
    CDEX can also do error correction.
    Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Posts
    2,901
    I use Audiograbber....Great Program and Free Now.
    http://www.audiograbber.com-us.net/
    Member
    Nov 2003
    USA
    Posts
    997
    Quote Originally Posted by jimmalenko
    it gives me an option to extract the audio files to a wav format. how do i convert it to a mp3?
    the second option is extract to compressed audio file...is that mp3?
    Member
    Nov 2006
    Posts
    7
    WMP rips into WMA and MP3 of your quality choice.
    Member
    Nov 2003
    USA
    Posts
    997
    maybe i should try WMP. In CDEX, it doesnt allow me to select the quality choice. It looks like it just randomly chooses it.
    Member
    Feb 2004
    Pleasant Hill, CA
    Posts
    586
    Did you look in the "Options"->"Settings" menu selection? There's an "Encoder" tab that should be what you are looking for.
    (Sometimes you just gotta take some time and poke around a bit )
    Jim
    VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Posts
    4,756
    Quote Originally Posted by jyeh74
    In CDEX, go to the Options menu, and pick Settings, then the Encoder tab.
    To rip tracks to MP3, pick your tracks and pick the button on the right that states "Extract CD Track(s) to Compressed Audio File(s)."
    Member
    Nov 2003
    USA
    Posts
    997
    Quote Originally Posted by Ai Haibara
    oh ok, mines was set b/t 128 and 224. so it just chooses when it increase and decrease? I noticed when i play the track it goes up and down.
    Jul 2002
    Sweden (PAL)
    Posts
    13,177
    That's called VBR MP3...
    /Mats
    Jan 2006
    Posts
    4,756
    If you want a CBR MP3 (the bitrate stays constant ), in the Encoder tab, set "VBR Method" to Disabled.
    Member
    Nov 2006
    Posts
    4
    I use audiograbber & also another free program called belight seems to do most things I need it to
    Member
    Nov 2003
    USA
    Posts
    997
    It doesnt matter if I set the quality to low, standard or high does it? Cuz either way, I have to set the bitrate myself.
    What is the version (MPEG 1 or MPEG2?)
    Member
    Feb 2004
    Pleasant Hill, CA
    Posts
    586
    When you are in the "Encoder" tab, click the "Help" button. Then select "Settings for Lame MP3/Blade DLL/Internal MP3 encoder:"
    Explainations of the "Quality" and "MPEG-I/II" settings are there.
    Jim
  1. Replies: 13
    Last Post: 14th Oct 2012, 20:20
  2. Replies: 2
    Last Post: 21st Aug 2011, 05:27
  3. Replies: 11
    Last Post: 25th Sep 2009, 04:39
  4. Replies: 1
    Last Post: 5th Dec 2008, 09:43
  5. Replies: 1
    Last Post: 5th Dec 2008, 08:07
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
