Hi guys.
I found this USB Hub on Craigslist, but the guy selling it doesn't know much about it.
Has anyone ever seen it before? Is it a USB 2.0?
Any help would be appreciated, but if ya don't know - no big deal!
Thanks guys.
Jenny![]()
Its neither and yet both ... then it comes down to who the heck made it ... some are not only rubbish , but dangerous and can cause system problems .
On it's own it dosent do anything ... it's just a usb quad port adapter ... works with usb1.1 and usb2 ... just increase's the number of usb ports on your pc system ... sometime's , depending on the length of the cable extension , they come in handy .
A note : You should check the current requirements of devices you connect to these adapters , and os required .
Most pc's usb deliver a maximum of 1 amp , this is shared by ALL usb connection's on the pc ... exceed this and the system can not only crash ... but under xp , if a warning similar to "usb reset due to overload" ... you will have numerous issue's .
Damage to the usb subsystem effects agp voltage ... onboard will be fine , but addon card will overheat eventually .
If you use usb2 capture device ... the capture ability will have degraded ... and the option here is to replace the motherboard .
In such case ... I recommend the "self powered" usb hub supplied by belkin be used to interface between such device's which delivers a maximum of 2 amps , thus taking any strain off the pc usb's power system .
This device comes with it's own power supply adapter .
Just giving you some advice from experience .
Golden rule to always follow :
If the seller dose not know much about what they are selling ... put your money in your pocket , and go else where . -
Hi BJS.
Well, you've helped me tremendously...I know it sounds lame, but I love this place for the help people give and receive...
Thanks so much.
And your Golden Rule wised me up...you forget about that stuff sometimes.
Thanks!
Jenny
LG DV382 - USB Port
By Yabuike in forum DVD & Blu-ray PlayersReplies: 15Last Post: 6th Oct 2011, 08:41 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
USB port on DVP
By hootal in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2008, 09:35 -
DVP5982 with USB hub?
By Fearnot in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Dec 2007, 15:44 -
USB 2.0 Port and RAM?
By LCE in forum ComputerReplies: 11Last Post: 6th Nov 2007, 01:01
